I have a dvd in 4:3 format. I just bought a wide screen tv and I'm wondering can I convert the 4:3 movie to 16:9 using dvdmaestro without causing the picture to be distorted in anyway? Or would it be best just to leave it as a 4:3? Thanks.
Scotsman
DVDMaestro just "flags" the video as 4:3 or 16:9. 4:3 or 16:9 is the aspect ratio and once a video is encoded at a given ratio it's stuck.
However, if you have a letterbox movie, you can normally use a Zoom button on your TV to remove most or all of the letterboxing.
You could also reencode the whole video bystretching it's height by 33% and then cropping back to 720 x 480 to create a new DVD that was 16:9. I've done that with a few videos and it works OK.
If you just use DVDmaestro to change the flags - the picture will be distorted on display unless you mess around with DVD and TV settings - you could possible come up with a combo that doesn't distort.
Multiple subpic aspects on still menus?
By EddyH in forum Authoring (DVD)Replies: 11Last Post: 29th Apr 2010, 09:43 -
Changing aspect ratio without losing any picture quality
By m93 in forum Video ConversionReplies: 9Last Post: 5th Apr 2010, 08:42 -
Distortion in FCP
By Daniel Corcoran in forum MacReplies: 7Last Post: 27th Jun 2008, 14:58 -
Distortion at the top of the picture with TBC turned on
By zanos in forum RestorationReplies: 6Last Post: 6th May 2008, 18:22 -
changing frame rate, making a better dvd picture
By motleycool in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2007, 02:30
