According to a Pioneer web site, (as of Dec 24, 2002)
the DVR-105 can burn "RITEKG02" DVD-Rs at 2X.
1) Is this correct?
2) Who sells these?
Are these RITEKG02 the $83-$85 per 100 Riteks that say 1X-2X
with A04/DRU-500A with right firmware?
CD Speed (select "Extra" from the menu, then "Media ID") can tell the media ID of your blanks, if someone can check.
Thanks!
I checked my Riteks with CD speed they were G03's and they burn at 1X and I have 1.21 firmware.
Thanks for the info mysterio1.Originally Posted by mysterio1
I wonder who sells the G02 then... -
never seen the G02's anywhere...The G03's are more recent and burn at 1x although one guy said he could burn at 2x with them...and after everyone had bought them from PC Shop or something like that said he could no longer do it...
The G04's burn at 4x. -
I read somewhere that princo 2X are G02's never tried those I have no idea if they work, and some other diferent branded DVD-r's are to but know what thiose are.
The G04's do not burn at 4x on the dru-500a. At least the ones I have don't.Originally Posted by bumblebe
Never seen G02s either, but after hacking my firmware I was able to burn at 2x with the G03s. My first attempt at doing so came out bad, so I gave up at the time. But last night I burned a perfect disc at 2x so I guess its not as bad as I thought.
Which drive's firmware did you modify?Originally Posted by flaystus
I assume an A04?
I have the A05...
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
A good, "easy" program that can edit a DVR disc?
By Arglameth in forum EditingReplies: 1Last Post: 23rd Feb 2009, 10:58 -
Will digital broadcasts have "IDs" to aid in DVR recording?
By ebenton in forum DVB / IPTVReplies: 10Last Post: 26th Apr 2008, 05:55 -
Pioneer DVR-107D mistakes certain DVD+R/DVD-R discs as "blank CD"
By litmus in forum DVD & Blu-ray WritersReplies: 3Last Post: 5th Sep 2007, 14:38
