For backing up DVD's on the PS2 what media works. I know alot of different types of media work but for how long. I have heard a couple reports that using cheaper media will cause the laser to burn out after a few months. Has anyone been using dvd-r's in there PS2 for a while now? And if so what media works for you?
i have a version 7 ps2 with magic 3. i have found that princo, memorex, and accu dvd-r work speratically. upon reading some posts, some one recommended ritek. i bought them and they work great. boot instantely. i have also read other posts that say verbatim dvd-r work great.
to sum up.
ritek dvd-r
verbatim dvd-r
i recommend ritek cause they are a heck of alot cheaper. -
I also have version 7 ps2 with magic and I found Bulkpaq Generation 3 and 4 both worked perfectly for games.
However, for films these disks got to about an hour and then they froze.
I then tried Ritek (traxdata, Lynx) and both these worked perfect and let me watch the films okay. -
around 4 months on my ps2.
had no problems but I have only been using ritek media which is good quality. -
:P ha i just posted in another topic saying these disc works with PS2 perfectly, here http://dvd-r.safewebshop.com and it's called universal media...
and again... use the coupon code they gave me... RTN03OFF takes a sweet $3 off ...(says only for return customer but... friend of mine use it anyways... -
Been using Verbatim dvd-r for a good while. It works very well in my PS2. Just bought some Ritek G03 and works in the PS2 also.
A Media Player That Actually Works On A 64 Bit System
By JayLovesKasesSky in forum Software PlayingReplies: 24Last Post: 5th Oct 2013, 08:06 -
Windows Media Center on Xbox 360 - how it works and codecs help!
By prankstare in forum Media Center PC / MediaCentersReplies: 6Last Post: 5th Feb 2011, 10:29 -
Problem with DivX yet works in Windows Media Player
By tmundrill in forum Software PlayingReplies: 1Last Post: 18th Oct 2009, 07:44 -
How Windows Media Encoder Works
By i-developer in forum Video Streaming DownloadingReplies: 1Last Post: 20th May 2009, 19:21 -
Media Player that works with MCE Remote
By TBoneit in forum Software PlayingReplies: 2Last Post: 30th May 2007, 17:13
