hello I have a big problem or maybe a small problem to others. I've recently started to rip my dvds for backup use into divx format. I used DVD Decrypter v2.4 to rip Titan AE. The results were the usual vob files. After ripping I use FlaskMpeg to convert the vobs to a usable avi file. I use the settings and everything said at the guide doom9.net. About 8 hours later FlaskMpeg is finish and the resulting avi file is perfect except for one thing. This imperfection is that when playing the avi file the images of the whole movie are upside down. I have no idea how to fix this, what I did wrong, etc. When using FlashMpeg the output is correct. Is there a program that can edit this? or a way to prevent this? or a better program to convert dvd rips to divx format.
DOC
Just today i started doing a dvd rip to divx and i did the same thing you have, but my file doesn't play...I've tried converting the VOB files to divx with dvd to avi and flaskmpeg, but they don't play... i'm not sure what i'm missing...point is: the file is there, but media player can't render the stream.
And to answer your question, try using VirtualDub and use one of the filters to flip the image around horizontally, vertically or in an angle.
Divx playback problems on DVD Player
By pblunn in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Feb 2008, 02:02 -
Problems converting DIVX files to DVD
By Jack_Dante in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2007, 13:12 -
Divx 2 DVD Problems
By KilinKind in forum Newbie / General discussionsReplies: 8Last Post: 8th Aug 2007, 08:03 -
DIVx to DVD problems
By ulm4lyf in forum Newbie / General discussionsReplies: 8Last Post: 17th Jul 2007, 00:26 -
Audio Problems with divx,xvid etc on dvd player
By iain123 in forum AudioReplies: 6Last Post: 30th Jun 2007, 14:57
