WHat program can I use to preview dif. VOBS on a DVD? So then I can choose what Bonuse stuff I want to cut off... Thanks
Yes I am a newbie!!!
Any of the software dvd players should do this if you drag & drop the vob into the players window, actually newer versions of media player will do this also.
Movie only DVD9 to DVDR guide.
http://www.angelfire.com/droid/dvdr/guide.htm -
Even easier way is to associate .VOB files with the player (use the Open With... function on a right click) - while you're at it - you may as well associate all the file types you need - MPG, AC3 etc
Then, just double click the vob and it will automaticcaly play it without having to have the player open first.
Saving view
By jyeh74 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2011, 14:18 -
Point of View camcorder
By Rhodie in forum Newbie / General discussionsReplies: 0Last Post: 7th Mar 2011, 10:53 -
How can i view my PC on my TV?
By awaisuk in forum Capturing and VCRReplies: 8Last Post: 23rd Jun 2009, 07:24 -
View folder changes
By jyeh74 in forum ComputerReplies: 5Last Post: 20th Oct 2008, 01:18 -
Sansa View 8 GB Model how do I convert video for use with the sansa view?
By goheadtry in forum Video ConversionReplies: 1Last Post: 2nd Jun 2008, 00:01
