it gave me an .001 and an .002 file. Then it also gives me mpg.1 and mpg.2 files. what do i do with these?? plz help
Use Powerdvd or Windvd and check to see if your mpg1 and mpg2 files play. If using Powerdvd, use file mode and look for these files and say "ok". If they play and look good enough to you, then go and burn them. Make sure the files are small enough to fit the cdr you plan to use. Hope this helps! PS I believe the .001 & .002 files were the files you used to make the mpgs 1 & 2 files from.
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Split 720P MPG File
By ap0091 in forum Video ConversionReplies: 2Last Post: 30th Aug 2008, 12:51 -
How to split a MPG file in specific parts
By bosstone75 in forum Newbie / General discussionsReplies: 8Last Post: 28th Nov 2007, 13:38 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35 -
Want to capture Right side of Split-Screen mpg clip from Woodstock movie.
By quark258 in forum Newbie / General discussionsReplies: 15Last Post: 19th Oct 2007, 05:12
