If i burn a VCD then delete it from my HD, is it possible to RIP it back to the HD ? If so how would i do this ? Should i store all my movies in AVI format ? How do you guys do it ?
D/load VCDGear, this will allow you to 'rip' your VCD to your HD. In theory you can just copy the dat file and rename it to xx.mpg, but this doesn't really/always work.
As for storage format it depends on what you want. I want to play everything on my TV so it's x(S)VCD. If you only watch stuff on your PC then DivX is a good choice.
Rip VCD to ISO without converting
By cynikalhedonist in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Mar 2011, 12:50 -
Rip audio from VCD
By miamicanes in forum AudioReplies: 9Last Post: 4th Aug 2010, 08:04 -
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 14:11 -
By c1steady in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2009, 06:40 -
help rip vcd
By Mjzchild in forum Authoring (VCD/SVCD)Replies: 1Last Post: 28th Jun 2007, 02:39
