One of the Project I've started working on it taking the coming Next week Promos of of the Original Series Star trek Disks and burning them onto a DVD. What I initially done. I ripped the entire disk to the HD using Smart ripper in File mode. I Used DVDAVI to identify which vob's had the trailers. It's at this point it becomes a bit hazy. I Would imagine I would need to convert each trailer to a standalone MPEG2 file. The use and authoring program to make menus that would allow you to pick which trailer to play, create chapter points, and add a play all function. Which would be the best method of doing the vob's to Mpeg's? Also the Trek trailers incorporate a menu at the beginning of it that would need to be trimmed.
Results 1 to 1 of 1
Movie Trailers?
By xxnonamexx in forum EditingReplies: 4Last Post: 5th Nov 2011, 14:02 -
is there an easy way to get trailers off of my blurays?
By AndyD in forum Blu-ray RippingReplies: 4Last Post: 18th Dec 2010, 11:57 -
Movie Trailers in Quicktime
By skorpinok in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2010, 11:39 -
Do these trailers play for you
By disturbed1 in forum Off topicReplies: 1Last Post: 18th May 2009, 11:54 -
In a world... where no trailers will be the same...
By MeDiCo_BrUjO in forum Off topicReplies: 5Last Post: 4th Sep 2008, 21:51
