    Sep 2001
    Japan
    When I try to insert a logo (surrounded with an alpha channel grey),I'm always getting a white border around my logo, which isn't present in the original image.The image is in targa file format.First I tried a simple Bitmap, but the border was a clear white.With the tgs it's getting better, but still prominent.Any ideas, how to get rid (or avoid) this problem?
    BTW: I installed 4 logoaway filters after this logo filter, but this is cumbersome.With these filters, the borders could be blended away,
  2. Sounds like you will need to fiddle with your alpha channel some more. I would recommend "shrinking" it some. In other words, brings the outside edges in a bit and blending it some.
    Good luck.
    Darryl
  3. I just thought about it some more... one trick you might try is creating the logo entirely in the alpha channel. Make the logo image just a plain white image.
    Darryl
    Sep 2001
    Japan
    The logo is not a simple text, which can be rendered as a white image.The logo itself is a multi-colored image, which should be blended into the video.
    I hope I understood you correctly.
    Sep 2001
    Japan
    I got it.The hint regarding white was a hit.I did misunderstood you there.I just tried to set the alpha channel to all white and bingo, the border is gone.Thanks a lot!
