HeY
I have a cartoon movie [the Magic Sword] and there is danish lanuage on
the dvd i have tried to get a program where i self shutt choice the lanuage "sorry my english" i want to rip it to vc ...
This is covered in all of the guides. Once you rip the vobs to your hard drive you are most likely going to use dvd2avi to create a d2v file which you will load into your encoder. In dvd2avi click on the audio tab and use it to select the language you want. If you reload the DVD in smartripper and go to stream processing it will tell you where each of the languages is stored ie: language 1= English, language 2= Danish etc..
