Im trying to dexmux in tmpgenc. And ive used some other programs in doom only to find out they are for windows 9x. Is there a program that is easy that can demux to a .m2v file and .ac3 file???
So were you and were you not able to demux in TMPGEnc ? I use TMPGEnc Plus (2.58.44.152) and had same problem with "Simple De-multiplex" option. It worked with "De-multiplex".
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
I wasnt able to demux. I have tmpgenc 5.10. I dont think it is plus. It is the free trial. It gives me the option of video stream, private stream, padding stream, and private stream 2. It tells me to Double click on stream which you want to save to file. I double clicked on video and it gave me a vts file that was a copy around 1 gig. I just want to split it to a .m2v file and .ac3 file. I havent figured it out yet.
5.10 ? You mean 2.510.49.157 (251049157 for search), right ? Let me see how that one looks. In a mean time can you post exact steps and file names that you are trying to deal with ?
I use de multiplex with a .vob file. I add it in and double click and it doesnt split it in to a .m2v file and .ac3 file.
Best Demux Software ?
By webstar in forum MacReplies: 15Last Post: 25th Apr 2013, 01:18 -
how do I demux an MP4?
By exekutive in forum MacReplies: 16Last Post: 27th Dec 2010, 02:43 -
Demux FLV
By canaQ in forum Video ConversionReplies: 3Last Post: 25th Oct 2010, 13:25 -
Trying to mux / demux
By GLE3 in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2009, 13:07 -
How to demux
By php111 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Aug 2007, 19:07
