I have two large SVCD/MPEG-2 files which I want to join, and then split into three parts. My standalone DVD player only supports SVCD with the VCD Header trick.
Since this is my first time both making an SVCD and cutting/joining, I was wondering, should I first multiplex the two SVCD files (use the VCD header trick to "re-encode" to MPEG-1) and then join and resplit them, or should this be the final editing step before burning? I hear cutting and joing MPEG-2 files is difficult to do perfectly and can cause a lot of errors in the resulting files. Would performing the VCD header trick be a potential way to avoid these hazzards?
Results 1 to 1 of 1
Splitting/cutting/joining MP4 accurately...
By The.King in forum EditingReplies: 2Last Post: 2nd Nov 2011, 12:35 -
Easiest software for compilation, cutting/joining?
By jiopi in forum EditingReplies: 0Last Post: 14th Oct 2010, 12:31 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 15:39 -
WMV cutting-joining-playback problems
By Cusem in forum EditingReplies: 2Last Post: 7th Dec 2007, 03:48 -
Alternative AC3 cutting and joining tools
By 557953 in forum AudioReplies: 2Last Post: 21st Aug 2007, 11:11
