ok,,,
i capture in vdub using huffy codec at 640x480, when i encode to svcd or vcd using tmpenc, looks/sounds great!
but when i try to use xvid codec in vdub it looks/sounds like garbage.
ill tell u what i do..
file->open video file,
video-> fast recompress
video-> compression
i select the xvid mpeg4 codec, then configure, i select '2 pass - 1st pass'
then advaced options, my settings look like this
http://members.rogers.com/ikai/xvid1.JPG
all other settings are left as default. under two pass 'discard first pass' is checked.
then i press ok and im back in the main vdub window, i hit f7 and give it a filename, with the bottom box checked so it adds it to job control and doesnt encode right away.
i go back to video-> compression
this time i choose '2 pass - 2nd pass int.'
then under advanced options my settings look like this
http://members.rogers.com/ikai/xvid2.JPG
http://members.rogers.com/ikai/xvid3.JPG
http://members.rogers.com/ikai/xvid4.JPG
http://members.rogers.com/ikai/xvid5.JPG
then i press ok to go back to main vdub window
audio-> full processing mode
audio-> compression
i select mpeg layer3, 160kbit 44khz, press ok and im back at main window
then i hit f7 and give it different filename. then i hit f4 and tell it start.. it encodes.. looks like garbage..
anyways ive seen some amazing samples from xvid i just dont understand what im doing wrong..
if any of u can offer advise it would be much appreciated. thanks.
Results 1 to 1 of 1
Encoding Xvid in 50mbps?
By 24fps in forum Video ConversionReplies: 11Last Post: 15th Aug 2011, 19:37 -
Xvid encoding
By fester77 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2011, 07:19 -
How to get Xvid encoding in VirtualDub
By Dr_Asik in forum Newbie / General discussionsReplies: 9Last Post: 25th Feb 2010, 10:31 -
Quick XViD Encoding?
By shorto in forum Newbie / General discussionsReplies: 5Last Post: 22nd Mar 2008, 03:54 -
Encoding with Xvid.
By Felo in forum Video ConversionReplies: 1Last Post: 26th Aug 2007, 00:38
