Hey there everyone,
I was just wondering if there is a way to increase the speed of CCE's encoding.
I remember getting speeds up to 1.6 and my computer is a p4 1.6 ghz.
now i can barely reach 1.2
I just formated last month.. i have cce 2.5 and i beleive all the patches, etc.
If anyone knows how... i'd appreciate it.
I also have SP3 for win2k.
Well first off your speed can vary quite a bit depending on your settings. Larger resolutions and higher bitrates will take longer to encode, filters can slow things down alot, and frameserved files will take slightly longer to encode than raw avi's.
Make sure your hard drives aren't fragmented, and if possible read your source from one drive and have the encoder output to another.
Experiment with different verions of avisynth, mpeg2dec, etc... -
unlike other encoders , CCE is VERY memory hungry
have as much memory free as you can
since you only have 256MB - look at going to 512 or more
Hey you can't have enough memory especially with W2K or XP
How To Speed Up and Slow Down the Footage
By blewyn in forum EditingReplies: 6Last Post: 25th Jan 2012, 22:46 -
Win7: slow down dvd speed
By themaster1 in forum ComputerReplies: 4Last Post: 1st Jan 2012, 20:03 -
slow wireless tranfer speed
By Eyecan'tcode in forum ComputerReplies: 16Last Post: 9th Jun 2008, 21:30 -
Slow down Video play speed.
By sureshforum in forum EditingReplies: 1Last Post: 1st Feb 2008, 23:51 -
How to slow down speed of Mpegs?
By lillei55 in forum Newbie / General discussionsReplies: 5Last Post: 10th Sep 2007, 18:40
