When I first upgraded to XP, my DVD ripping speed was remarkably fast (up to 12-13x); I could rip Attack of the Clones in under 15 minutes. The entire time, I received this "error" when loading SmartRipper 2.41 stating that no ASPI layer was detected. I thought nothing of it and moved on.
Recently however, while ripping the extended cut of LotR, I noticed a dramatic drop in my ripping speed, down to 2, MAYBE 3x if I'm lucky. The odd thing is that I changed nothing, no new hardware, no new software, the same system I had a few days before getting the uber-ripping speeds (and still getting the ASPI layer "error").
So I tried installing the latest ASPI layer, as linked via the Tools section of this website, and, for me, it did jack for my ripping speeds. Heck, I think the ASPI may have reduced my ripping speed by about 0.5x.
Here is a screen cap of the ASPI check program that came with the package:
Could the two missing components be the key to this problem? If so, how would I find those components?
Thoughts? Ideas? Suggestions? All are appreciated.
I have had better results using DVD Decrypter.If you get the same ASPI
error with DVD Decrypter d/l ForceASPI(located in Tools). -
I don't get any sort of ASPI error with DVD Decryptor, however the ripping speeds are no different.
This ForceASPI program ... it is safe to run in WinXP I assume? The last thing I need right now is to f- something up and have to format.
ForceASPI is Adaptec ver. 4.60 it was written for Win95 and works on all
Windows OS.It sounds like your ASPI layer is fine and that your rip speed depends on the disk and your DVD-ROM.The fastest i'm able to rip is 7.1x
with DVD Decrypter.
Ripping speed for dvd-r
By vcd4me in forum DVD RippingReplies: 10Last Post: 22nd Apr 2011, 06:45 -
Errors on Shrink ripping latest hit dvd's
By bluzjamer in forum Authoring (DVD)Replies: 9Last Post: 6th Dec 2010, 01:13 -
Ripping Blu Ray to Dual Layer DVD?
By gbreeze in forum Blu-ray RippingReplies: 10Last Post: 26th Dec 2009, 23:27 -
Dual Layer Burn Speed
By webstar in forum MacReplies: 8Last Post: 17th Sep 2009, 01:37 -
Latest solution in ripping and shrinking DVDs?
By SirDracula in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2008, 15:25
