The logic behind 'what to do' is relatively straightforward as follows -
1. Can the DVD fit onto a DVD-R with no changes (< 4.3 Gbyte) ?
Yes - Simply, rip the WHOLE DVD, burn.
2. Can the Movie fit onto a DVD-R if you strip the menu's and extras ?
Yes - Rip just the movie, recreate the ifo's with ifoedit and burn.
3. Can the movie fit onto a DVD-R with the extra's stripped completely AND the extra audio streams/subs etc stripped from the main movie ?
Yes - Rip the movie, delete the extras,strip the unwanted streams,recreate the ifo and burn.
If still NO, then there is only one option left (to fit onto one DVD-R that is) and that is re-encode to get the bitrate down.
So finally, rip the movie, delete the extra's,strip the unwanted streams, re-encode the Vob's (<4.3 Gbyte), recreate the IFO's and burn.
There you go - a very simple way of looking at things !!
Cheers,
TeeeRex
(Mods - previously posted in the DVD to SVCD section but more relevant here I think ... apologies for the double post...)
You can also determine size and rip just the parts you need to begin with. Another option is to CUT the credits at the end of the movie if you are cutting it close.
when you say Yes - Rip just the movie, recreate the ifo's with ifoedit and burn.
do you delete the original ifo files and copy the new ones ifoedit creates into the VIDEO_TS folder?MAC -
Create a VIDEO_TS folder and direct IfoEdit to put all of it's output into this foder. You will get new Ifos and Vobs and 2 Bup files. This is so you don't get the old and new confused when you burn.
JasonK, I would really appreciate your help in learning how to delete the credits at the end of a movie. It seems like they are always embedded as part of the final VOB,... there is no separate VOB for them.
Also, teach me how to cut out the Warner Bros. logo that is embedded in the first VOB of the main movie. I have a movie that is down to 4.7 GB after everything is stripped out except the logo and the credits and I don't want to re-encode. I've tried that and takes much to long. I'm trying to learn how to do things like this so I can use it over and over again,... it's not just for one movie.
Thanks in advance."Technology",...It's what keeps us all moving forward.
putting dvd files (VOB) from dvd and using in windows live movie maker
By emmawharmby in forum DVD RippingReplies: 8Last Post: 20th Feb 2012, 06:58 -
HD Video to DVD and buying decision HD camcorder
By ddinc in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Dec 2009, 07:17 -
Burning DVD's with Roxio Creator Basic 9 or Windows DVD maker
By bhess55 in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2008, 02:55 -
WMV to DVD compliant MPEG2 - TDA3 or DVD Maker - what is the right way?
By MagicSparky in forum Video ConversionReplies: 5Last Post: 23rd Aug 2007, 12:27 -
Vista Movie Maker and DVD Maker problems
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 22:18
