Currently using DVDit! SE and had no problems creating DVD folders for later burning until last week when i tried and it came up with a warning message saying 'Each GOP header must be preceded by a sequence header'. Can anybody tell me whats going on and how i sort it out.
Thanx
PS if i posted in the wrong section, sorry!
You probably need to re-encode your file and make it DVD Compliant.
An MPEG video stream consists of a succession of GOPs (group of pictures). Each GOP starts with
one complete video frame (called an I-picture or I-frame), which is only moderately compressed. The
following frames (called P-pictures and B-pictures) contain only information that is different from
the I-picture, and are therefore much more highly compressed. Larger GOP sizes help to compress
the video more, because there are fewer I-pictures per second of video.
Because the I-picture is the only complete image in a GOP, it is the only frame where you can insert
a chapter point or pause the video.
The DVD specification requires a sequence header before each GOP (the sequence header contains
information about the MPEG stream, such as aspect ratio, GOP size and bit-rate). DVDit! does not
support MPEG streams without sequence headers. Check your encoder’s settings to ensure that it
creates sequence headers before you encode MPEG files for DVDit!
MPEG-2 video:
36 fields/18 frames (NTSC)
30 fields/15 frames (PAL)
Some encoders generate MPEG-2 streams with variable GOP sizes. DVDit!
supports these streams, providing the GOP size does not exceed the above limits.
Frame rate:
29.97 Hz (NTSC)
25 Hz (PAL)
Aspect ratio:
4:3 or 16:9 anamorphic
Bit-rate:
Constant bit-rate (CBR) or
variable bit-rate (VBR)
2.0 – 8.0/9.4 Mbps
If you use PCM audio in a project, the maximum video bit-rate is 8.0 Mbps.
If you use Dolby Digital, the maximum is 9.4 Mbps.
Filename extension: .m2p, .m2v, .mp2, .mpg, .mpeg, .mpvMichael
Learn to create DVDs the Ezway
DVD Related Question Post them at
www.EzDVDAdvisor.com
DVD Developers Community
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 13:51 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 11:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 22:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 00:51
