hi, i read on the site that for an mpeg to be vcd compatible it should be 1150k/bit per second, and on the tmpgenc web site it says it encodes it 2.4% higher, making it 1177.6.
so my question is, should i set it to 1122.4 thus the actual mpeg bitrate will be 1150, or doesnt this matter?
i need to have the vcd perfect because i want to play it on a sony dvd player which i believe are a bit dodgy with cdr's.
thanks,
russ
if your looking for the perfect vcd then how you want the quality is up to you. 1150 is just not good enough for for me. i have played around with different settings and found for myself that to get a good quality movie, you have to up the bitrate, makeing the file larger, and putting the movie on 2 cdr's. but that's my personal preference. my suggestion is to take a small mpeg file, like about 30 seconds, and encode it multiple times at a different bit rate each time. then you can judge for yourself what quality you'd like to use.
how can I reduce bitrate and frame rate when converting avi to mpeg-2(dvd)?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2011, 04:42 -
MPEG bitrate
By paulys in forum Newbie / General discussionsReplies: 3Last Post: 20th May 2009, 22:00 -
AVI to MPEG smallest bitrate?
By michcio in forum Video ConversionReplies: 11Last Post: 29th Aug 2008, 20:09 -
Variable bitrate Mpeg-2
By miggeth in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2008, 08:58 -
MPEG-4 to MPEG-2 using CCE 2.50 OPV: How not to waste bitrate?
By Fran-K in forum Video ConversionReplies: 5Last Post: 4th Apr 2008, 08:38
