I have a bin file that I cannot delete from my hard drive. Each time I try to it says that someone else or another program is using it.
I have tried to delete it in safe mode but this doesn't work either. Any suggestions please.![]()
Boot up into MS-DOS. Navigate to the folder and delete that stubborn little bastard.
do you have clonecd , daemon tools or any other phqantom cd drive installed?
Isn't this file mounted by that software? -
Don't delete it. I'm using it...
So did it work when you closed clonecd?? Try rename it and if it works you should be able to delete it. -
It won't let me rename it because it says it is being used by another person or programme.
For AVG users (missing bin file)
By stiltman in forum ComputerReplies: 6Last Post: 17th Aug 2008, 23:16 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Opening .bin file jpg
By chewie8008 in forum ComputerReplies: 4Last Post: 18th Jul 2007, 16:01 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 13:05 -
how to burn a BIN File
By Chris 67 in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 07:44
