hey! I got Pinnacle PCTV USB.
I live in europe, using PAL.
When I capture video from TV (320*240), using Pinnacle's software, I lose lots of frames at fast times, and I get even more loses if I capture with Virtual Dub using PICVideo MJPEG Codec.
I tried disabling my Norton Anti Virus and closing other background programs... it didn't help!
PLZ HELP ME!
I got P3, 733MHZ
and 128MB RAM.
4GB free space.
I realize you are not using an ATI product, but I suggest you work your way through:
How to Tune your system for ATI capture cards---General guide
http://www.vcdhelp.com/forum/userguides/81808.php
Most of this guide applies to capture cards "in general", just skip the ATI specific part (mainly step 14.) -
hi,
if your capture soft doesn't seem to work, after trial an errors,
i'd suggest you to try some other capture soft. avermedia
capture soft is the worst thing i've ever seen, so i tried!
greetings,
sunmanking
High Quality Capturing with Little Frame Loss in VirtualDub
By monsoon01 in forum User guidesReplies: 65Last Post: 18th May 2013, 22:33 -
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
WMP and VB6, is it possible to step forward or back frame by frame?
By gadgetguy in forum ProgrammingReplies: 11Last Post: 6th Mar 2009, 20:00 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53
