I have recently ripped a DVD using smartripper which lead to a set of VOB files of over 5 Gb.
I used DVD2AVI to create a file I could load in TMPGEnc and I re-encoded it to fit on one DVD+r, which resulted in a .m2v file and a .Wav file which together was less than 4.7 Gb.![]()
These files produced with TMPGEnc play fine with synchronised sound etc in PAL format using a software DVD player.
I then needed to re-author the DVD, and for this I could only find IFOedit to produce a new set of VOB files. This seemed to work fine and said it had no errors and produced the VOBs quite quickly.
However, when I play the VOB's produced in this way, the video plays back slightly jerky, and at what appears to be a faster framerate than the original 25fps PAL, and the sound is totally out of synch![]()
Does anyone have any idea for the cause of this as I have redone it 3 times now with the same result, and can't see any parameters that would be causing this.![]()
thanks in advance
Brummieman
If you remuxed the m2v with Ifoedit that's your problem. You need to use Ifoedit 95 in author mode. Ifoedit does not remux m2v files created with Tmpeg or CCE properly,audio synch problem. It works in remux if you encoded with Rempeg however.
2 small questions about authoring with IFOEDIT
By i_j_2009 in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2010, 10:15 -
Which dvd authoring software should I use? IFOEdit keeps crashing.
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2009, 05:54 -
ifoedit/sony vegas-->sound problems
By carock in forum Newbie / General discussionsReplies: 3Last Post: 5th Nov 2008, 10:28 -
Usinf IFOEdit to correct an error in authoring
By netmask56 in forum Authoring (DVD)Replies: 3Last Post: 30th Nov 2007, 22:30 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 15:37
