Hey all,
I've just got my hands on a DRU-500, so I'm trying to learn about ripping to DVDR.
I presume that, like with other media, the amount of video that a DVD can hold is a product of the file length (in minutes) and the video bit rate.
So, in order to fit A Beautiful Mind (130 min) onto a DVD-R (4.7Gb / 120min) I’ve ripped with SmartRipper and re-encoded with ReMpeg2 and authored with IfoEdit. This has worked exactly as the guides have said it would.
However, I’m having problems with Three Kings (111 min). By rights, after stripping out the unnecessary files it should fit onto a DVD-R without having to re-encode. But it doesn’t (4.8G), so does this mean that the bit rate is set higher than normal, in which case I have to re-encode, or have I still left something unnecessary in the rip
Regards,
Rob
It should? How do you figure? A DVD will hold 4.3 (4.7 million bytes). So there's no way 4.8 gig will fit. You can verify you rip out extra audio streams (sometimes several hundred megs) and credits at the end of the movie. If it still doesn't fit, then you have to reencode (compress further) or split to 2 DVDR.
I wasn't expecting it to be 4.8G because it was 'only' 111mins long, hence my question about length and bitrate.
Regards,
Rob -
Like you said, it's also a function of bitrate ALSO. So reencoding will lower the bitrate. Regards.
This then raises the question whether some DVDs have video files with artificially high bitrates so as to prevent copying without re-encoding (not really a barrier, but definately offputting to someone still using a PIII or equivalent). There must surely be a point at which the increased bitrate is lost on the average TV.
Regards,
Rob -
DVD's are encoded with VBR (variable bit rate) - bits are used as needed.Originally Posted by rhegedus
Chances are they figured they'd be over the 4.7 limit with the extras and what not and just set a higher average bit rate for the hell of it.
-d
Double .mpls playlists same length and size BUT different names
By Caeasarea in forum Blu-ray RippingReplies: 6Last Post: 17th Sep 2011, 19:27 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 09:08 -
Newbie question for creating a DVD
By DaBooch in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2010, 18:51 -
Newbie-Question about DVD Player
By sohancool in forum Newbie / General discussionsReplies: 0Last Post: 21st Mar 2008, 00:00 -
Newbie-DVD format question
By plemal in forum Newbie / General discussionsReplies: 16Last Post: 14th Feb 2008, 15:06
