  1. I had to re encode Blade 2 ( pal) with rempeg because it was to large, after running it through Spruce up, i still had 2 "m2v & ac3 files
    i renamed that ones that i had encoded as
    blade2-encoded.m2v &
    blade2-encoded.ac3
    after going through spruce up Then burning off with Record now, the movie plays with glitches & skipping, played on my standalone whic is a multi region TEAC one & also my PS2, havn't tried my XBOX yet but on the Strand alone TEAC player , it would come up with the menue's and it would start to play the movie, but only the sound? ( still showing the chapeter selection)
    & in the PS2 it would play with glitches & skipping, then it would play smooth, then i'm sure when it gos into the next chapter it would completely stop & say "Unable to read Disc"
    Can anyone please tell me where i went wrong with REMPEG as i havn't had any drama's with my others, because i havn't had to use rempeg.
    or The fix for skipping play after rempeg ( which options to change )
    Thanks in advance
  2. this is exactly the reason i changed from rempeg2 to cce.
    if the film needed encoding anything below 80-85% i always got this.
    since changing to cce i have never had a spot of trouble.
    thingimijig.
  3. Ok thanks so much for that info thingimijig, i will definetly give CCE a shot, i hope it's easy to use as i am still fairly new to DVD 2 DVDR.
    Just ahppy i don't have to go back to DIVX now,
    Thanks again, i will et you know how i go, Thanks for the usefull info.
    B-boy
