A freind of mine has a Sony DRU120 (I'm waiting on a DRU500), and a Toshiba SD1300 DVD player. According to this site this player should play +RW disks. However, only in mode2(?). She only had B's Gold CD burning software, and I tried a trial version of Ulead DVD MF2 (she's converting home movies etc), but the Toshiba would not recognise the disk.
I tried using MF2 to create folders(VIDEO_TS) on the hard drive, and burn with B in mode 2, but no luck.
I burned a DVD+RW with MF2 and took it home, where it played on my Hiteker(Apex) 5131 and 1000 and Singer SDG001.
The bit setting utility does not work on this drive (apparently), and she is not one to flash the firmware etc or mess with her new PC.
So............(sorry for the long winded explanation), can she use Nero or something else to burn in a compatible mode(2?) etc or do we really need to change a bit setting?? or should she look for a new DVD player??
Tried this one? Works fine on my drive...(HP200i)
http://www.dvdplusrw.org/resources/bitsettings.html#pc
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 02:17 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
HDC setting question, 2 pass + manual bit rate
By jsbenson in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 20:15 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 12:12
