hi,
i work with Adobe Premiere (6.5) recently, but didnt find out how to cut out certain frames out of a movie. I know how to cut at beginning or end, but how can i delete some frames from a movie? (without havin to cut it in several pieces)? which tool do i have to use for this?
any answer appreciated! tia![]()
I'm pretty sure that to delete frames, you'll HAVE to cut in some places. Use the razor tool. Just click it where you want your first segment to end, and click it again where you want the second segment to start. Then put away the razor, select the unwanted section, and delete it.
Hope that was helpful. -
thx for ya answer
& ya right i have to cut it (works exactly how you described, or using the "In-" and "Out-points")...
greetz
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Newbie - Adobe Premiere/Computer Horsepower
By rgibson in forum Newbie / General discussionsReplies: 8Last Post: 11th Jan 2011, 08:13 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Total Newbie- Need help Premiere Elements 4- Two cameras Rendering
By VitalExpressions in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2010, 21:53 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43
