  1. Can you make buttons in tscv so be easier moving around through menus by just pressing which direction to go and pressing enter rather than pressing numbers on my dvd player? If tscv can't make buttons is there another svcd authoring program that can? Have any good suggestions please reply asap. Thanks
  2. No. SVCDs do not support 'true menus' with buttons. That's DVD only. The best you can do is to make a menu with numbers (1, 2, 3...) then you can hit the number or your remote to go to that section.
    Only other option is to try to burn a miniDVD/cDVD or get a DVD-RW drive, sorry.
