Hello can some one help me with this problem ? How can I record strait on to video tape from the timeline ? I have tried to do it this way. Export timeline/print to video but it did not work. The button under print to video (export to tape) is checked and I cant use it. Is this why its not working ? Thank you for your help in advance.
I had this same problem, but I figured it out. You first have to tell the program how long of a black "leader" you want to put in front of the taped portion you're sending back to your camera. Then, when the black leader shows on your monitor, you have to manually put your camera in the "record" mode. I'm surprised that the program doesn't do this for you, but I guess you can't have your cake and eat it too, after all.
Adobe Premiere export same as original file?
By kray in forum Newbie / General discussionsReplies: 13Last Post: 9th Sep 2012, 01:05 -
Best export settings in Adobe Premiere CS4
By Polesch in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2010, 18:45 -
Help Help Help! Premiere AgedFilm Export problem!
By qisheng in forum EditingReplies: 0Last Post: 26th Dec 2009, 13:03 -
Adobe Premiere Pro: I used DV footage and Photoshop stills - how to export?
By neckneck in forum EditingReplies: 12Last Post: 20th Dec 2009, 16:29 -
FLV Import/Export Nellymoser audio - Adobe Premiere CS4
By shagen in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2008, 18:38
