Hey!
I have Geforve 4 ti 4200 ViVO and Im tryin to capture some TV. My problem is that PowerVCRII and WINDVR have bad MPEG2 encoders (cant blame them, they are real time) so I want to record to AVi. for some reason i cant tell Vdub to use Svideo so i cant use that but i can use UIVCR which i found good but has that annoying 30 day thing. ANy other utilities i should try
If you can't tell V-Dub to select S-Video for your input, you may want to re-install the capture drivers.
My Gainward board works just fine, I just have to manually select "S-Video" every time I want to capture.
Just go "Video", "Source", then on "Select a Source" pick "S-Video" on the drop-down box. -
I have such a junk card, yet it does capture with the s-video in, so yours probably should too.
Mine's currently up for trade(for a AIW7500)/sale on a local newsgroup -
PowerVCR2 and WinDVR2 have GREAT mpeg2 capture abilities.
If you choose the right settings to use with them.
My captures are SWEEEET.
Fozz -
Ok, say, it's encoding quality is something people won't all agree on. I didn't like it. Besides, I'd rather capture to mjpeg then do post processing (crop, cut commercials and all) then encode.
Well,
I just ran into another problem w/ iuvcr. Like after 5 minutes of perfect capture oto huffy, i start dropping frames. and the end movie is jumpy and skips every second. i defragged my drive but still. always after 5 minutes. (7200 rpm HD Maxtor, I am thinking of getting a WD 120 GB w/ 8 megs of cache, does that cache really help for captures?)
Can someone tell me thier most successful settings for WinDVR. Every time the scene changes, it is pixelated for a second and i cant figure out a way to make it not be. Thanks for your input
easycap svid
By cesar110 in forum Capturing and VCRReplies: 0Last Post: 24th Sep 2011, 17:23 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 11:55 -
Capture Software for VHS to MPEG/AVI
By quantass in forum Capturing and VCRReplies: 1Last Post: 7th Sep 2007, 15:22 -
nvidia geforce 7800gs AGP V's geforce fx 5500 AGP
By stackner in forum ComputerReplies: 5Last Post: 15th Jun 2007, 15:22
