Is there a program, or is it even possible, to convert a stereo wav or mp3 file into some form of 6ch ac3. I thought perhaps Scenarist could do it but I had no luck.
Results 1 to 9 of 9
The DEAD are alive again!
I am having a similar issue, I rip a dvd from the origional and then use dvd2avi to get the sound track off but its only in 2 channel pcm. I dont know if you are ripping off origional dvd's but that would be the best way to do it. I have used all the tutorials but it still does not work. If anyone has these issues please reply so we can figure this out. Am I using the wrong settings in dvd decrypter or dvd2avi? Can I make the *.wav file into a dolby digital 5.1 (*.ac3) or dts? Thanks for any help from anyone.
Pickupork -
well you could convert a stereo wav file to 6 mono channels and encode it to 5:1
but that is not surround sound and in some cases can make it sound worse ..
if you know what you are doing - there are ways to re-mix a stereo to surround sound .. though using mp3 as the source is poor idea IMO .. -
By the way I have tried to demux all tracks and all I get is a bunch of 500MB files i think 6 or 7 of them.
Pickupork -
there are many ac3 encoders -- do a search here for the names of some of them ..
there are only 2 DTS (dvd type) encoders - both are very expensive .. -
I tried using BeSweet but the file is not accepted by Dvd Maestro. Can you rip the ac3 track off the origional?
Pickupork -
i would suggest smart ripper ... lots of guides here at this site or here also http://www.digital-forums.com/dvd2dvdr/
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
converting WAV to MP3 and preserving timecode
By soundie in forum AudioReplies: 3Last Post: 2nd Jul 2010, 14:33 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 15:12 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 23:45 -
Converting WAV to MP3
By igorek in forum AudioReplies: 5Last Post: 1st Jun 2008, 21:25
