hey all...i was wondering if i can extract the audio into wav or mp3 from 1 chapter... it's a live performance dvd and i just want one song turned into mp3...is there a way.
thanks
Yup:
First RIP the DVD with Smartripper 2.34
Let DVD2AVI decode the DVD audio. DVD2AVI can handle two types of DVD audio. You need to identify which audio format your DVD is using and which track number you want to convert. You can identify the audio format, number and language using SmartRipper.
(Most of the time a file called like VTS_01_INFO.TXT is placed by SmartRipper and at the STREAM INFO you find out wich is it)
Then you convert the wanted section to MP3 with Cooledit by example.
Goodluck!
Rgrds, Co. -
Yes I think you must. Don't know any other way, perhaps someone else does?
that's what i thought...i just don't have the space for the vobs right now. thanks anyways
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 24th Jan 2011, 00:28 -
Having a problem with some vobs - audio, no video.
By architectofpain in forum Software PlayingReplies: 2Last Post: 24th Dec 2008, 10:41 -
no audio in .vobs
By UncleBose in forum DVD RippingReplies: 2Last Post: 7th Oct 2008, 16:51 -
DVD Lab Pro - Using VOBs, Audio Problems
By teacozie in forum Authoring (DVD)Replies: 5Last Post: 24th Sep 2008, 02:12 -
Dvd Vobs: change audio from LPCM to AC3 2.0
By biancolone in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 07:16
