I'm using eazyvcd to rip and encode, and vcdeasy to burn. The quality is great, better than I hoped, but no chapters. This means if I need to get to the 50 minute mark in a movie, i have to wait 25 minutes b/c it only has 2x fast forward. It's a cyberhome 500. This dvd player also has a goto feature where you enter what minute and second interval you want to get to , but it doesn't work on vcds either. AAAAAAARGGGGGGHHHHHHHHHHH!!!!!!!!!!!!!!!
thanks 4 your help!
I am not familiar with the program EazyVCD but are you sure that it actually makes VCD chapters?
There are numerous guides on the net (and this site) on how to make VCD chapters. Chapters using entrypoints on VCDs work as thus: http://www.michaeltam.com/chapters.html
For the beginner (and most guides use this proggy too) VCDEasy would be the easiest way to make a VCD with chapters.
Regards.Michael Tam
w: Morsels of Evidence -
Here's a guide for creating chapers:
http://www.vcdhelp.com/sefy/?id=chapters2.html
Hope That Helps!!! :P
Thanks puertorican, but the instructions say this:
Step 3a - Press the "Chapters" menu item and Here you can select to import the Chapters for your movie, Right Click to get the popup menu so you can import from Smart Ripper or Chapter-X-Tractor.
How can I do this if I used eazyVCD to rip and encode. EazyVCD uses Vstrip and the BeSweet, if this helps. I appreciate the effort!
James
Want to use K-Lite? - DON'T DO IT!
By jeanpave in forum Software PlayingReplies: 45Last Post: 15th Nov 2010, 23:04 -
I don't get it?
By penny1stu1 in forum Newbie / General discussionsReplies: 1Last Post: 5th Apr 2010, 06:34 -
Need Help But don't know how to ask the question
By NickHedge in forum Newbie / General discussionsReplies: 5Last Post: 8th Mar 2010, 05:23 -
don't like what's on tv?
By deadrats in forum Off topicReplies: 2Last Post: 16th Feb 2010, 10:42 -
Subs don't show properly I don't know what to do
By atai in forum SubtitleReplies: 1Last Post: 8th Oct 2009, 08:44
