Hey guys,
I have used both Pioneer and Princo DVD-Rs, and I find that Princo's media really are cheap for a reason. In price and quality.
Low downs...
Princo: Cheap price, but crappy media. Always causes DVD video glitchs close to the end of the movie. Video/Data above 4GB has data glitches no matter what you use to verify with. Also quality is NOT consistant. One disk may be more glitchy than another burned exactly the same way.
Pioneer: Really expensive, but data is protected very well. The underside of the DVD-R edges are very clean, and the same quality as the inner parts of the disk. Princo disks have an outer edge which is really poor in quality (Read above about Princo).
Any comments about other DVD-R/DVD-RW media you have tried? Post it!
Results 1 to 10 of 10
I only use Ritek G3's.
Under $1 each and compatibility is superb. I've burned dozens of movies with no playback errors or coasters.
-d -
Do you label your DVD'sOriginally Posted by Trenton_Net
http://www.vcdhelp.com/forum/viewtopic.php?t=138166 -
I'm in the same boat as this guy. I'm looking over my shoulder at my DVD-R rack, and what must be 140 movies. Not a single problem with any one of them. I get my Ritek's at www.mediasupply.comI only use Ritek G3's.
Under $1 each and compatibility is superb. I've burned dozens of movies with no playback errors or coasters. -
You get what you pay for. I dont use any of the cheap crap out there cause i care about my final output. I use Verbatim, TDK, and Maxell and havent had any problems.
hi,
I cannot comment on the Cheap MEdia as i have never used it so far. I use Verbatim+RW for testing and Memorex and TDK so for as i good Good deals on those from COMPusa for $1 each for 20 TDK and 3 Memorex. So i use them right now. Once i use all of them i may try some cheap Media but if i get Deals like this Them Probobly i will use branded media. -
I usually use datawrite or white label dvd-rw for video, as they play fine on my standalone. They're under £1 each & I can always re-use them.
I have some really cheap bulkpaq disks, but don't/can't use them for video but they're fine for data. -
Where can i get the ritek G3's for under $1 each in a 50 pack? I want to try them. I use princo's and i do get problems at the end of least 1 of every 12 movies.
http://www.supermediastore.com/dvd-media-ritek.htmlOriginally Posted by Roland187
they only sell 25 packs and 100 packs. The 25 packs work out to about 1.15 each, the 100 packs are $.91 cents each - they were on sale for .83 cents a few weeks ago.
Princos are junkola. I've burned dozens of movies and peoples acting reels and haven't found a player that supports -R media that has any playback problems at all.
-d -
I use universal brand media at http://dvd-r.safewebshop.com for my DVR-105 great product great ppl, something for people who wants pioneer/mitsui quality but reasonable price. also use these disc to back up ps2 games.
also i got a coupon from my first purchase here guys "RTN03OFF" it says for return customers only but friend of mine use it for his first order and discount still applied
New to double sided dvd's - Burning Hi Quality Media Files
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2012, 21:50 -
Samsung SH-S243D DVD writer - CD media burn quality
By onland in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Feb 2012, 23:52 -
Quality TDK Media?
By hech54 in forum MediaReplies: 15Last Post: 24th Jan 2010, 20:42 -
VOB & MPEG4 HD to Windows Media Compatable Format (DVD Quality?)
By RobsterNo1 in forum Video ConversionReplies: 2Last Post: 28th Oct 2008, 07:49 -
Quality of output different between media players?
By bigshotceo in forum Software PlayingReplies: 3Last Post: 7th Feb 2008, 02:43
