I've just download an XVID file. The problem is, when I go to play it back, it plays upside down.
How can I fix this?
I don't know if this is any help as I am new to all of this.
I've just downloaded the Nimo Codec Pack off a website and it had a note at the bottom to say which not to install
One of them was called Bicubic Resizer Filter and it said only install it if you have files that are upside down.
I'm guessing if you install this pack (has to be the most updated (ver 5.0 build 9) with the Bicubic filter you might be able to fix the avi in VirtualDub.
Don't know if it will work or not (as I said, I'm new) but it might be worth a try.
Good Luck -
You need to change the 'Flip Video' setting in the xVid codec.
To do this, run Media Player 6.4
Start>Run>mplayer2.exe
Open the video file.
Click File>Properties
Select the 'Advanced' tab.
Double-click 'Xvid MPEG-4 Video Decoder'
Put a checkmark in the 'Flip Video' option.
Thats it, no more standing on your head in front of a mirror!! -
Or turn your tablet PC the right way
Panasonic DMR-ES45VS, keep those discs a burnin' -
kitty.... and I was just about to say "flip monitor upside down"
You were faster
Spaceboy, sorry for my stupid comment, but somtime I have to post somethink like this. :PPinnacle Studio 8 and DV home video editing (ver.9 already home)
MPCHC plays all DVD upside down
By mysts in forum Software PlayingReplies: 2Last Post: 29th Nov 2010, 10:35 -
AVI file only plays audio. no video
By lauren.eriksen in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2009, 21:56 -
avi files upside down
By nocash in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2008, 08:13 -
Build 2.5.3200 - Successful AVI-conversion - Upside down image..
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 4th Oct 2007, 17:58 -
My backup AVI file plays choppy
By rayc1234 in forum Newbie / General discussionsReplies: 14Last Post: 11th Aug 2007, 15:39
