  1. Is it possible to have files of different bitrates on one VCD? I'd like to put a couple of TV episode encodes on one disc without resampling them to the same bitrate if possible.
  2. Member Conquest10's Avatar
    Chicago, IL
    yes but if they are different bitrates than 1150 they are called xvcds.
  3. Originally Posted by Conquest10
    I realize that. However, I'm not talking about one constant bitrate for the entire XVCD but two different bitrates for two different files/tracks on the VCD.
    fmctm1sw, so you're saying it can be done, but the resulting XVCD may not be completely stable?
  4. It can be done. You can put up to 99 MPEGs on each CDR and each can have it's own resolution and bitrate.
    No problem.
