I'm using VirtualDub to capture. I have a VisionTek Xtasy Everything. I'm using Hi-8 as a source.
In VirtualDub, I'm finding that as I capture different clips, they come out sometimes with the bottom field first (expected) and sometimes with the top field first (unexpected). I'm using Huffyuv 2.1.1, capturing at 720x480.
I check the field order by using a method previously posted in these forums (going to TMPGEnc, going to deinterlace, select Even-Odd field and "scrolling" through the clip watching for frames jumping back and forth).
Is there a way in VirtualDub to force the capture card to capture the bottom field first? Does anyone know why the field order would switch when capturing successive clips from the same source/tape?
-mjf17
If I just deinterlace all the AVIs then there will be no more fields and the problem is solved right?
-mjf17
Need info on field order for capturing mpeg video
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 22nd Dec 2010, 07:58 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
Reconciling different Field Order
By vegasarian in forum EditingReplies: 8Last Post: 14th Mar 2009, 11:43 -
Field Order Problem?
By GordRocks in forum Authoring (DVD)Replies: 3Last Post: 4th Mar 2008, 09:19 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14
