Say i have the full dvd backup to my hard drive,how would i go about demuxing the video and audio stream,as u would if using dvd decrypter.??
Well you could do it a lot of ways.. depends on how your files look. If you have literally all of the files the best way is probably to make an .iso and then rerip it with dvddecrypter as if it were a real dvd using daemontools or some other virtual cd/dvd program. If you don't like that option the blelow option would still work fine with a full rip.
If you have the vobs but not everything then vobedit with the "demux complete title set" option and that is probably the best option. Or you could always use the newly released virtualdub that is modded to support vobs directly. Or you could use the program doitfast4u and tell it to demux from HDD. Or you could do it one of a million other ways that are probably just as good. There are literally more ways than I can count to do this.
If you JUST the move vobs and no proper _0 or _ifo files then the easiest thing you can do is to use vobmerge to merge into one big vob and then vobedit as above. -
assuming you no longer have the DVD (otherwise just re-rip).Originally Posted by Haku
download daemon-tools.com, create an image file in nero, then mount
the image in daemon tools and point decrypter to to the new virtual drive.
-d
Best Demux Software ?
By webstar in forum MacReplies: 15Last Post: 25th Apr 2013, 00:18 -
Demux FLV
By canaQ in forum Video ConversionReplies: 3Last Post: 25th Oct 2010, 12:25 -
Trying to mux / demux
By GLE3 in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2009, 12:07 -
Demux Problem
By Felo in forum Video ConversionReplies: 2Last Post: 16th Jun 2008, 02:42 -
How to demux
By php111 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Aug 2007, 18:07
