i just bought a hp dvd writer...(its external)..going to install it tomorrow..but I have 2 questions 1. whats the easiest way to backup dvd's?...i was checking out some of the guides here...one said to use dvd decrypter..and then ifoedit...and then burn with nero or ulead..(which is better?)....now i see theres something new called dvdtodvdr...dont have the money for a prog like that...but are there any similiar progs like that.... 2. if you have old svcd or mpegs...is it easy to burn them...i heard somewhere you had to convert vcd and svcd's to dvd format..what is that?
whats better smart ripper..or dvd decrypter....and two things 1. is it possible to put the special features and other things..so its just like the original dvd AND 2. i joined 2 svcd files...using tmpgenc...and the first half..is inaudible...cant hear anything..but the 2nd half..whats up with that?
so any thoughts about joining the svcd....i got no sound for the first file..(first half)..and sound for the second half..using tmpenc..
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
