Seems that I have messed my encoded Survivor episodes big time. I captured the episodes from TV to Pinnacle AVI and encoded them to MPEG2. Now whe I started to burn them on DVD all episodes flicker in motion scenes, so I think the field order has been set to upper field first instead of lower field first.
My question is:
Is it possibe to change this in the MPEG2 files without re-encoding or should I encode them again with lower field first setting? I don't have the original AVI files anymore so there will be quality loss if I encode them again.
Thank you for help!
I couldn't get the program to work. Also is it only for NTSC material? My MPEG2 files are in PAL format.
Info from pulldown.exe readme file:
Should work for PAL too.To change the field order to odd on a stream that you accidentally encoded as even:
pulldown.exe source.m2v target.m2v -nopulldown -tff odd -
Get the gui for Pulldown.exe. A quick search on google for 'pulldown.exe' and 'GUI' should net you some results. Much easier...
Impossible to see the future is. The Dark Side clouds everything...
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
How do I change the field order on Moviefactory 5? Please!
By jayndani in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2009, 07:42 -
How do I change the field order in Moviefactory 5?
By jayndani in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2009, 05:42 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14 -
Need to change field order
By Loko in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 21:32
