I am sure this question has been asked many times.
I have some MiniDV Camcorder home movie footage I would like to record to VCD. I will shortly be purchasing some software to allow me to encode directly to MPEG1 from the source.
However, at the moment, I am limited to recording from the source into .AVI format.
The only problem is, the AVI file is HUGE. A 1 min clip totals approx 200MB. This would make a 60 minute home recording into an unmanageable size.
I read of people converting AVI files to MPEG1. My question is, how big do your AVI files get??!! A 5 min clip for me would be 1 GigaByte and 60 mins would produce a 12GB file!
Not really a big deal coz of the MPEG software I'll be getting soon, but I'm just curious. What are the AVI capturing techniques you guys use?? I guess people converting from AVI to MPEG must have huge hard disks.
I do this all the time and the results are great and fun. I can compress 2 gigs (? about 20minutes of video) to about 50-100megs (going from memory), but it really depends on your setting. The software I use is TMPGenc to convert AVI to MPEG-1. Note, TMPGenc is free and downloadable so you don't have to wait!!!
The conversion to MPEG-1 takes a while though. -
Yeah, I use TMPGEnc to encode my captured AVI files as well. I capture using VirtualDub with Huffyuv compression - 30 minutes takes up like 4 gig or so, I think. Cutting/editing the AVI file using VirtualDub usually takes a bunch more disk space. Lastly, I encode to MPEG-1 (VCD) using TMPGEnc and it takes like an hour per 10 minutes of video on my Athlon 800.
If you don't already have a big hard drive, buy one -- they're pretty darned cheap now!
-Zak -
DV runs at about 3.6 MB/sec. Compared to many capture formats, that is actually quite small. Be glad you're using DV and not an analog capture card with Huffyuv, which can easily require 10 MB/sec at DV resolution.
-Cart
http://www.geocities.com/lukesvideo/index.html -
Thanks for the info everyone.
I think my problem lies in my AVI captruing software. I currently use MGI Videowave III. I will try VirtualDub and see how that goes.
Yep, I agree with the comments about TMPGEnc... I think it's a really cool tool!
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 06:31 -
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 22:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 20:32 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
