I've tried some templates but they dont help much. I want to know which is the best VCD template that will play in all VCD compatible DVD's.
use the one in the template folder named video cd (ntsc). that is a normal vcd and is the most compatible.
With TMPGEnc, you could set the "Motion Search Precision" setting to "slow". This will lead to slower encoding but higher quality.
Changing bitrate and/or framesize will lead to non-standard encoding.
Regards.Michael Tam
w: Morsels of Evidence
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 17:04 -
A simple, easy to use website template?
By sdsumike619 in forum ComputerReplies: 2Last Post: 23rd Apr 2008, 06:02 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 09:09 -
Substituting Variables in a Wiki Template
By thecoalman in forum ComputerReplies: 1Last Post: 14th Jul 2007, 05:00 -
Template selection in CCE...
By hiimbored in forum DVD RippingReplies: 5Last Post: 28th May 2007, 19:54
