okay, i own both an APEX AD-1200 and a panasonic/nintendo gamecube Q. when i burn dvd-rs, i can read them perfectly fine on the Q. however, when i try playing them on the apex, it reads them as a dvd, but then freezes up. i have read other posts about this, but no matter what i do in IFOEDIT it doesnt seem to solve the problem. same thing with DVD-RW. is there any other way around this or can anyone help me? thank you very much!
--eric
Same thing happened on my Apex 703. Sony 665 playes ok. Tried several cheap DVD players around - only Philips played it but with artifacts. But it does not happen to all disks. Some (especially those copied with Nero's disk copy option) play just fine.
Here's the solution. Do not use Nero to create DVDRs - it does not follow the standard. Use different tool to create DVD image (I prefer Maestro). Then burn that image with Nero or DVD Decryptor. Of course it takes more time and you need extra 4.5 Gb disk (has to be NTFS for single file). But then it plays on every DVD player that supports DVDR.
Hope this helps.
I have a DVD-R that I burned 1200 songs on, my DVD player only can read 600
By frieday in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2010, 05:31 -
trouble with playback on 4Hour movie
By item9 in forum Authoring (DVD)Replies: 5Last Post: 29th Dec 2008, 11:51 -
Winstar 1200 DVD player - region free?
By CuriousKristy in forum Newbie / General discussionsReplies: 1Last Post: 14th Apr 2008, 12:31 -
DVD playback trouble
By shorto in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2007, 11:06 -
Trouble with video playback
By najac in forum Software PlayingReplies: 3Last Post: 6th Aug 2007, 16:00
