Hey there
I jst bought my self a Pioneer 105 DVD-RW. When i try and burn a DVD Movie in Gear Pro 6.02 i get a buffer under run. I thought it may have been a software probelm, but NERO burned fine but one of my DVD players could not recognise it. So i went to search for another DVD burning program and found Prassi PrimoDVD 2.0 I installed it but it wont recognise my Pioneer 105 drive so i cant burn any DVD's!!
It also take me about 30-40 mins to rip a DVD on my Pioneer 105 drive. Is this the normal rate or is it drastically slow? if so what can i do to improve it? I am running Windows XP Service Pack 1.
Any help would be much appreciated
Cheers
ChicaneWeaver
Hi friend,
you will need to go to the prassi web site and download the patch so your pioneer 105 will pick up. -
I have burned many dvds and all are fine ( I used Nero) My best guess is that you used some cheap media. I would recommend tdk and sony. I used those with no problems.
=[ vinchi007 ]= -
Hi thanks for your help!
Where can i get the PrimiDVD Patch? Also what is everyones recomendation to the best DVD-RW burning program?????
Also... what speeds do people get ripping DVD's with the Pioneer 105? It takes me about 30-40 mins to rip a whole movie
Cheers
ChicaneWeaver -
Hi friend,
You can get the patch for primo dvd at
http://www.prassieurope.com/
ok
VOYAGERXP -
Another thing you might want to check is that the drive is set to DMA mode and not on PIO mode. I always used to get the buffer underrun problem with my cd burner until i fixed this.
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 10:04 -
WQXR 96.3 FM classical music radio station moves to 105.9 FM, New York
By vhelp in forum Newbie / General discussionsReplies: 1Last Post: 8th Oct 2009, 22:16 -
edited material back to tape. Sony DCR-105.
By freelance in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 15th Nov 2008, 11:06 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 13:23 -
Buffer overflow in tmpgenc?
By themaster1 in forum EditingReplies: 7Last Post: 15th Jun 2007, 17:08
