Been Rippping my DVDs with SmartRipper then using vob2audio(0.1.0) to give me a wave file so I can dump it to MyDVD with the m2v file made with TMPGEnc.The reason for this is that if I use infoedit it won't play on my DVD player but if I use MyDVD it works on mine and all my mate DVDs..This is for shrinking DVDs that are larger than 4.3Gig...Vob2Audio gives me this cryptic message...Ligos Splitter seems to miss an Audiostream.Use AudioVob option in Smartripper or use VobTool to delete first segment......I've tried ticking and un ticking the Audio Streams in SmartRipper but I'm stuck..Any Help
Results 1 to 1 of 1
Get rid of Directors Commentary using Demux?
By Bushy162 in forum DVD RippingReplies: 3Last Post: 11th Jul 2011, 06:24 -
Directors Commentary - How to Remove
By jah711 in forum Blu-ray RippingReplies: 12Last Post: 26th Feb 2009, 22:43 -
Directors cut/Commentary backup Only
By jah711 in forum Blu-ray RippingReplies: 0Last Post: 7th Jan 2009, 09:20 -
unrated and directors cut dvd's...what is new?
By lordhutt in forum Off topicReplies: 2Last Post: 1st Sep 2008, 01:51 -
How Can You Tell which one(s) are the directors commentary
By jah711 in forum Blu-ray RippingReplies: 1Last Post: 25th Aug 2008, 01:00
