  1. Can someone explain to me what is an FTP exactly and what would be a good one to use? Thanks, Miller 8)
  2. FTP = File Transfer Protocol. It's a way to send files over the internet. Instead of http:// in the address it starts with ftp:// - logons are sometimes needed although many sites allow anonymous or login-less access.
    Internet Explorer will do FTP if you use the ftp:// front part of the address. There are some programs like CuteFTP etc. but some of these"free" versions have adware or spyware. You can check programs at tucows.com
    Panasonic DMR-ES45VS, keep those discs a burnin'
  3. Thank you Kitty! Miller
    Aug 2001
    Dallas, Texas; U.S.A.
    The best FTP program is FTP Explorer, you can find it at
    http://www.ftpx.com
    it's free for personal use, AND NO SPYWARE!!!
    -Epi
