  1. i finally got moviefactory 2 and tried to edit my mpeg2 file in it tht i capture using dazzle stat 200 well when i finally burnt the dvd it came up outta sync....... I THOUGHT THEY WOULDA FIX THT DAM PROBLEM FROM THE FIRST ONE..... is there a update yet for this problem.... because mf2 is the only other authoring software tht is editing mpeg2 from my capture device
  2. Does your Dazzle program allow changes in the MPEG2 type? There is "Program" and "DVD' type streams. Some cap programs like that for the WinTV PVR 250 allow you to choose.
    It has come out that many authoring programs like the Program stream better than the DVD Stream although the reason is not exactly clear to me. But audio sync is retained.
    If you can change the stream type try Program & see if the sync is better.
    Panasonic DMR-ES45VS, keep those discs a burnin'
  3. i have watch just the captured mpeg2 file and audio isnt outta sync its only when i run it thru m.f 2 tht it becomes tht way
  4. anyone else havin this problem..... let me know
