When I try to encode some movies in tmpgenc and when i select the vcd or svcd original templates that came with tmpgenc. When I click next all is good but when I get to the file output size it says its around 2 gigs. The .avi file I downloaded was only 670 mb. Any help would be nice. Thx.
Its not the size of the avi file that matters it is the length. A 2GB vcd compatible mpeg would be 200 minutes, if your AVI file is this long then it is not a problem. If it is not this long then TMPGEnc is probrably misreporting the output filesize because the avi has variable bitrate audio. TMPGEnc cannot handle VBR audio and will misreport the output filesize if the source AVI has VBR audio. The audio would also be out of sync when encoded. To solve this problem follow this guide.
http://www.vcdhelp.com/divxtovcd.htm#audio -
KK thx i converted it to .wav but hen i put it in tmpgenc it still estimates the same output size. I didn't want to waste my time to not use wizard and see if it came out at 715 mb at 1150 bitrate. Thats wat its supposed to come out as but When i have it in wizard with my video and seperate .wav file it still estimates 1.7 gig.
Thanks for ur help.
Its supposed to be 715mb ? is it 71:30 long then
You first said the estimated output file was 2GB now it 1.7, has it reduced. And what is the length of your video.
Oops I messed up.
I'm such an idiot, sry for wasting ur time.
This movie lenght is 89 mins long and when i put directshow to highest prority it was 893 mb for vcd. But i thought i encoded a video before that was the same lenght but it wasn't the same lenght, it was 71 mins long.
So i messed up.
Juss one more question now when i put directshow highest priority it goes it says it can't open or it not supported my file which is .avi
Thx. :P
Need Help using AVStoDVD - Output size is HUGE
By Ronny G in forum Authoring (DVD)Replies: 42Last Post: 23rd Dec 2012, 21:27 -
Output size in AVStoDVD
By VenusAndMars in forum Authoring (DVD)Replies: 2Last Post: 25th Nov 2010, 18:07 -
WinAVI output file size
By Akusai in forum Video ConversionReplies: 21Last Post: 5th Oct 2009, 07:54 -
different output file size in convertx2dvd
By Iwan2learn in forum Authoring (DVD)Replies: 13Last Post: 13th May 2009, 03:29 -
Different DIVX codec, different output size.
By DonGallego28 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2008, 10:08
