In tmpgenc 2.55 when I convert from divx to VCD, everything looks fine and dandy, however when I convert to SVCD I get this look of pulsating bits throught the picture. I've provided a sample in mpeg-2
www.skepticmedia.com/mi-16-test.zip
No matter the selection, this seems to happen, the original Divx does not have this problem and encoding it to vcd works fine. the info on the divx are as follows:
Frame Size / FPS / us pf: 480x256 23.976 fps (41708 us)
# of frames (time): 126400 (1:27:51)
Decompressor: DivXMPEG-4 Low-Motion
Key Frames 1567
This also was a vbr divx <audio>
If someone can tell me how this happens and how to get rid of it, that'd be great. been plagueing me for months.
"True POWER goes to the ones who know POWER Starscream, Desire alone is not enough." -Megatron
-=Sabrtooth -
Someone has to have some ideas or links to show another way to do this
please let me know.
-=Sabrtooth -
Ive also been experiencing the same problem with 2 DIvx files of mine. Ive tried using 2 different encoder programs and both have the same result. TNPG and CCE both will not convert to SVCD without the pulsating white box. VCD works for me though. So if you happen to figure it out, please post it or let me know because it has been troublng me for a while now.
Thanks -
Since it seems no one likes to help here, I came to the conclusion on my own. How you can get it to work is to encode it in CONSTANT QUALITY (CQ) in tmpgenc. Dunno about CCE
-=Sabrtooth -
I tried that twice also now...with two different files. is there any other settng you had to change that may have affected it?
no thats all I did, make sure you download my clip to make sure it does do the same thing.
-=Sabrtooth -
I am positive that my problem is exactly the same as yours. I would upload a copy of my own problem if i had the capability. If you really have no idea, then its okay but if anyone else does, please help. Its kinda annoying having to make vcds now.
thanks
iTunes + Windows XP 64 bits, how?
By NormaJ in forum Software PlayingReplies: 11Last Post: 29th Dec 2010, 23:14 -
Vista 64 bits with 32 bits programs
By skaleton in forum ComputerReplies: 9Last Post: 15th May 2009, 12:41 -
SVCD2DVD crash on xp 64 bits
By alkirah in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 5th Jan 2009, 09:17 -
How to go over bits of a movie... editing sound
By UmmAddan in forum EditingReplies: 2Last Post: 22nd May 2007, 19:58 -
Why would the bits/pixel drop?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 8th May 2007, 04:55
MPEG-4 Low-Motion
