Hi,
I need to convert a PAL VCD to NTSC, without changing the audio: it means that I should choose either 25->24fps or 25->30fps. The amount of motion isn't too high, but isn't too low either: it's just "moderate".
Obviously I get jerky motion in both cases, but I remarked that the conversion 25->30 (the duplication of a frame for 5 times during a sec.) seems smoother than the conversion 25->24 (one removal of a frame during a sec.) Is it just me, or my observation is the same as everyone else's?
If this is the case, then I would expect that the reverse NTSC->PAL conversion it is preferable to be done from a 30fps source, rather than 24fps source, even if my intuition tells me otherwise. What is your experience?
As a general conclusion, what is less objectionable: (1) frame rate modification done more often (either up or down), or (2) frame rate upconversion via duplications (rather than downconversion via removals)
I heard there are Adobe Premiere plugins that do a smart and good job, but I am bound to using free software, which means I am limited to choosing between frame duplications and frame removals. I use TMPGEnc with the maximum quality settings.
Best regards,
Cosmin
Here's 2 guides that can help:
http://www.vcdhelp.com/pal2ntsc/pal2ntsc.htm
http://www.vcdhelp.com/forum/userguides/78178.php
Hope That Helps!!!
:P
I know all this, thanks. My problem is that I must keep the audio, so I must do real frame rate conversion. It introduces jerky motion no matter how I do it, and my question was how do I get a minimal damage.Here's 2 guides that can help:
Cosmin
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
