Hi, I just got a weird WinDVD/WMP related playback problem with my fresh from the oven mpeg file (DVD PAL, TMPGEnc)
The problem is this, when I open the file using normal Windows Media Player 6.xx (utilizing the WinDVD codec since I don't have any other mpeg2 codec installed), the video plays about 1-2 seconds, and then it freezes, but the audio is still playing fine. But when I play it using the real software (WinDVD) it plays fine both the video and audio!
anyone got the same problem? is that a WMP & WinDVD codec bug thing or the encoded file is faulty? I use TMPGEnc 2.59 and using the DVD PAL template and FYI the mpg is accepted with Ulead DVD Workshop 1.3 as a DVD PAL compliant file.![]()
I would guess that this is just a quirck of WMP and that, unless you want to install another MPEG2 codec, that there is nothing you can do about it. Is there a reason you need to use the Windows Player? I would suggest just using WinDVD for playback, or if you need something that works well with TV outputs (such as myself) I would suggest something like Zoom Player 3, which is free and feature-rich.
Hope this helps,
Prospero -
Hi,
I've the same issue between WinDVD & PowerDVD.
The first one works fine... the second freezes the authored DVD files (or mpegs too)...
After burning I've tried the DVD on my Home Player (Samsung) and.... same issue as PowerDVD shows!
My conclusion: Use PowerDVD to test your files before burning.....!
Best,
Marco
recent video taken w iphone, plays fine on phone, but not recognized on PC
By ryoaska1 in forum RestorationReplies: 0Last Post: 17th Oct 2011, 21:36 -
multiAVCHD ISO Plays Fine, but No Audio After Burn
By Brett4u6 in forum Authoring (Blu-ray)Replies: 1Last Post: 26th Aug 2011, 08:15 -
BetaMax plays fine for a while then bad picture
By LSchafroth in forum Newbie / General discussionsReplies: 7Last Post: 24th Nov 2010, 20:31 -
Video DVD that doesnt play audio on DVDplayer but plays fine on computer ?
By hiavi in forum Video ConversionReplies: 6Last Post: 15th Jan 2009, 14:01 -
VHS plays fine on TV, bad when captured...
By rachel.twu in forum Capturing and VCRReplies: 15Last Post: 9th Jun 2007, 23:38
