HELP! I'm stuck! I'm using an ASUS 7700 Deluxe (Nvidia GeForce 2 GTS) composite in and VirtualDub software to capture VCD compliant AVI. I also have a Soundblaster Platinum. If I capture a less than 4 gig file, everything works perfectly in one file. If I need to capture longer, and enable multi-segment, the first segment (2 gig) is perfect, and about 45 seconds into the second segment, I lose my sound for the rest of the segment. If I encode it with TMPGEnc the sound turns to loud white noise at approx. 45 seconds in to the second segment and stays white noise to the end of the segment. But if I use MS mediaplayer to watch the captured AVI, it will play THROUGH the 45 second spot and sound fine, but if I fast forward past it, NO sound, and if I rewind to any spot after the 45 sec. spot, no sound. If I rewind to BEFORE the 45 sec. spot. sound is fine. So there is SOMETHING weird about approx 45 seconds into the SECOND captured segment. This has happened EVERY time. And EVEN weirder, the third segment captured is perfect, no sound problems. I've wasted hours/days because of this problem, does ANYONE know what is going on? How can I fix it? PLEASE?
Thank you.
Results 1 to 1 of 1
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
weird audio/video wrong-synced problem
By michcio in forum Authoring (DVD)Replies: 9Last Post: 11th May 2009, 13:23 -
Ripped dvd conversion to xvid/divx weird audio problem
By victoriabears in forum Video ConversionReplies: 1Last Post: 12th Feb 2009, 13:41 -
Weird Audio
By Thr0ttleman in forum Video Streaming DownloadingReplies: 8Last Post: 4th Apr 2008, 05:57 -
Looping audio on GUI for DVDauthor menus weird problem
By chewie8008 in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2007, 09:16
